Mirage 2000B instructional at Orleans
hans van herk
Messagepar hans van herk » Lun 25 Juil 2022 15:09
Noted on 14 July 2022 at Orleans/Bricy was a Mirage 2000B stored in the area where the Transalls are parked.
It seems the aircraft is an instructional airframe, maybe in use with the fire brigade.
I am looking for the identity of this Mirage. Hope you can help me.
Regards,
Hans van Herk
aviateur28
Re: Mirage 2000B instructional at Orleans
Messagepar aviateur28 » Jeu 28 Juil 2022 19:49
Je suis aller aux informations concernant le Mirage 2000.
Il n'y a pas de mirage 2000 pour les pompiers de la base d'Orléans.
Le seul avion instruction c'est un Alpha jet et les carcasses de TRANSALL.
Hello,
I went to information about the Mirage 2000.
There is no mirage 2000 for the firefighters at the Orleans base.
The only training plane is an Alpha jet and the TRANSALL carcasses.
hans van herk
Messagepar hans van herk » Ven 29 Juil 2022 08:07
Thank you for your reaction
That is strange. It was definitely not an Alpha Jet.
Is a purpose built airframe, looking like a dual seat Mirage 2000 in use in that area of the airbase?
The aircraft is parked in the spot I marked on the overview.
Fichiers joints
aviateur28
Messagepar aviateur28 » Ven 29 Juil 2022 13:44
Hello,
Sur cette zone que tu montre il n'y a que des TRANSALL.
Pour information je travail sur ce site et j'ai posé la question aux personnes concernées.
Et pour ton info l'entrainement des pompiers ne se fait pas a cette endroit.
Hello,
On this area that you show there are only TRANSALLs.
For information I work on this site and I asked the question to the people concerned.
And for your info the training of firefighters is not done at this place.
:buba: :buba: :buba:
Messagepar BEN » Sam 30 Juil 2022 20:19
Si vous avez le numéro de l'Alphajet ....je suis preneur :wink:
aviateur28
Messagepar aviateur28 » Sam 30 Juil 2022 20:39
BEN a écrit :Si vous avez le numéro de l'Alphajet ....je suis preneur :wink:
BEN, je serait avec ma voiture mardi, donc si j'y pense je vais allez voir.
Je sais que c’était un alpha-jet qui était au parc a ferraille sur Châteaudun
